305 to 350 TPI swap
Old Jan 29, 2006 | 03:00 PM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
305 to 350 TPI swap
I didnt know which part this would go in...
What would you have to do to put a 350 in place of the 305 and use the old TPI setup?
Old Jan 29, 2006 | 08:47 PM
Shagwell's Avatar
Car: projects.......
Mostly it involves swapping the motor... j/k - A 305 is identical to a 350 other than bore size. EVERYTHING else is the same. Cam size/injector size/chip tune will be different, but nothing major for a stock/mild 350. If your 305 is a hyd roller, I hope your 350 is, or you'll be down-grading...
Old Jan 29, 2006 | 10:32 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Was it 89 when they did the switch?
Old Jan 30, 2006 | 12:13 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Could you explain thos further? What exactly is a "hyd roller"? What is the other type? And whats the difference?
Just trying to educate myself a bit on engines.
Old Jan 30, 2006 | 09:23 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
You have hydraulic roller cams 1987 and up. Befor that was a flat tappit ( someone clear up if it was mechanical or hydraulic ???)
I recomend a good book "building small blocks on a budget" It's part of the HP books series I believe . It covers alot of the basics . .... I just forget some of it
Hydraulic roller cam . The tapit has a roller on the end to contact the lobe of the camshaft. Instead of just a flat piece of steel or a rounded end . The bearing take some of the friction away and helps to keep things a bit cooler ( fiction= heat) . The tappit is filled with oil ( SOMEONE SAY WHY PLEASE) . All I know is . If yuo have a SOLID roller cam you need to adjust the rockers more to keep the same valve geomatry. So for a street car the hydraulic roller is a fine cam .
Old Jan 30, 2006 | 07:57 PM
teapot3208's Avatar
Car: 1985 Camaro
My friend wants to buy a car and do this swap...thats why Im asking. If it is a rydraulic roller, what can he do to make it perform like or better than (hopefully) a 350? Its a IROC 305 5-speed TPI. THX
Fast355
Dec 2, 2016 06:33 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
