surging problem
Old Feb 6, 2006 | 01:15 PM
91Z28CAMARO32's Avatar
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
surging problem
what would cause my engine to surge really bad and cause it to stall plus im getting code 16. High battery voltage OR
Direct inition system open or shorted to ground
Old Feb 6, 2006 | 01:40 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Vacuum leak can cause a surge. Never seen a code 16 before. Have you checked the batt voltage with an external meter??
Old Feb 6, 2006 | 06:13 PM
Car: 91 Z28 CAMARO
yes everything is a normal voltage
Old Feb 6, 2006 | 06:29 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
I dont know off hand what code 16 is.
Have you checked TPS voltage? a bad TPS will cause surge.
alt. is what sends voltage to bat. have you had it checked? (it might have a bad diode.)
Old Feb 7, 2006 | 10:04 AM
Car: 91 Z28 CAMARO
YES I HAD IT TESTED THE BATTERY AND ALT. IS PUTTING OUT 15V
Old Feb 7, 2006 | 10:07 AM
Car: 91 Z28 CAMARO
NOW THERE IS ANOTHER THING WRONG WHEN I STAR THE ENGINE IT SHUGS AND SKIPS BAD AT FISRT I THOUGHT THE CATALAC COVERTER WAS CLOGED CUZ IT WAS SPITTING EXAUST BACK THROUGH THE MANIFOLDS SO I TOOK OF THE CAT AND IT WAS CLOGED BUT IT STILL RUNS THE SAME SOME PEOPLE SAY IT COULD BE A SHORT OR BAD GROUND SOME WHERE
Old Feb 7, 2006 | 12:25 PM
Car: 91 Z28 CAMARO
man this is bull**** now the computer is spitting codes like crazy by the way this is a v6 mpi with coil packs not my 383
codes im getting
15. Low temperature indicated at engine coolant temp. sensor
I CHANGED THIS ONE
THIS ONE SHOWS UP EVERY TIME BUT THE REST DONT DEPENDS ON HOW IT STARTS UP
21. High voltage at throttle positon sensor
43. Low voltage at electronic spark timing circuit
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
