Does the 86 Trans Am have an in tank fuel pump?
Old Feb 7, 2006 | 04:13 PM
Francis's Avatar
Hi all, this is my first, so please excuse me if I have asked a question that has been asked many times before or if it seems stuiped to ask.
I have a 5L 1986 Trans am and are wanting to clean up some of the mess left behind from the last owner. He has installed a Holly Stealth Ram and several fuel pumps along with a surge tank, under the car to get the high pressure required. I wanted to just install one quality pump about 12" lower than the tank it self. I'm unsure if I have to keep the surge tank and if these had an in tank pump.
Thanks for any help you can offer.
Francis.
Old Feb 8, 2006 | 12:05 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
If it came with factory fuel injection, it has an intank pump, but an inline pump is a common mod for these cars.
Old Feb 8, 2006 | 01:07 PM
Vader's Avatar
Mine does, but it's TPI. IIRC, even some of the later model carbed engines had a pump in the tank.
Old Feb 8, 2006 | 03:57 PM
Francis's Avatar
Thanks guy's for the help.
Old Feb 8, 2006 | 04:32 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
my 86 Trans Am 5 Speed with Quadrajet 4bbl didn't have an intank pump.
Old Oct 16, 2019 | 09:15 AM
Chakadog's Avatar
Car: 1987 Firebird, Trans Am
Engine: 5 Liter (305 cu. in. Carburated)
Transmission: Automatic
Re: Does the 86 Trans Am have an in tank fuel pump?
My 87 Firebird Trans Am 305 with 4 barrel carb has an electric fuel pump in the tank and a mechanical fuel pump on the engine, I am the original owner bought it new that is how it came from the factory
Old Jul 20, 2020 | 09:58 PM
buckshot72kg's Avatar
Does the electric one make a significant whining/humming noise when you return the key on?
Is there a way to just go to a “regular” pump for a 5L 305 4 barrel carb? I’m a new owner to an 86 and can’t figure out if this whine is a good thing or bad thing now that it’s quieter on idle but noticeable as I’m driving - when I got the car it was just obnoxious
tahnks in advance
Old Jul 20, 2020 | 09:59 PM
Thanks in advance
Old Oct 10, 2023 | 10:39 PM
TonySnow87's Avatar
Car: 1987
Engine: 5.0
Do you have any information on these in line fuel pumps? I have an '87. Thank you
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
