lt4 hotcam
Old Feb 12, 2006 | 01:02 PM
5.7tpiroc's Avatar
Car: 89 Iroc
Engine: 5.7tpi
Axle/Gears: 9 bolt posi w/ 2.77s
lt4 hotcam
will a lt4 hotcam be streetable with the stock converter or will i need to get a stall? thanks
Old Feb 13, 2006 | 02:36 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
very streetable. I have one in my daily driver. You may have to get your fuel-air-spark tune-up adjusted though. not sure if it will run with a stock chip.
Old Feb 13, 2006 | 02:49 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Streetable with a stocker, just better results with some more stall :-)
It should run on your car without major tuning. It just wont be anywhere near its best :-) It should be made to run if u take the time to make sure everythign is set mechanically and electrically and the TPS and IAC are adjusted properly. Hit the prom board and do some research and you can be tuning yourself for not a lot of $$$$.
later
Jeremy
Old Feb 13, 2006 | 05:51 PM
5.7tpiroc's Avatar
Car: 89 Iroc
Engine: 5.7tpi
well i have a hypercrap that came with the car, and have no experience in prom burning, don't have a laptop anyways. will the cam work with my current chip?
Old Feb 13, 2006 | 06:02 PM
Shagwell's Avatar
Car: projects.......
actually the stock chips tend to be better than the hypercrap/superchips. It may run(many do) on the "stock" tune, but having it properly tune will help driveability and performance.
Old Feb 14, 2006 | 06:55 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
oh yea, it'll run with your stock chip... i have a higher stall and slightly modified heads, but still have the stock chip. i have an electrical problem that should be fixed this weekend (hopefully), so once that's done and i can finish breaking in the motor, i plan to take it to the dyno and have it tuned there, but it runs well as it is.
KAM
tommy z-28
Oct 6, 2015 10:58 PM
thekurlyone
Sep 30, 2015 12:54 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
ssgt usaf
Sep 21, 2015 12:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
