Lt-1 with a tpi harness?
I was wondering if it was possible to run an Lt-1 with the stock mass air harness. I was trying to do the swap with out killing my stock harness. I would do the mod to the intake to run a standard distributor, but just wondering if it was possible. The lt-1 is out of a 95 and the car is an 87 so they are both mass air. I realize that it would be batch fire instead of spfi. Just seeing if I am whack for trying, Thanks guys
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
you will need to have a hole cut in the intake for dist.(www.lt1intake.com) remove the egr and air tube bypass the opti-spark run new fuel line from the frame to the regulator.its not hard but if you need to have emissions you should convert the harness to an lt1
IBrockZ
Aug 20, 2015 12:20 PM
Sanjay
Aug 12, 2015 03:41 PM
