Heads, Cam and Roller rockers.
Old Feb 13, 2006 | 10:24 PM
TeK-91z28's Avatar
Car: 91 z28 convert
Transmission: 5speed
Fairly new to the whole v8 game. I'm looking to make my 305 have a better bang for the buck.
I have a ZZ4 Camshaft I want to install, what roller rockers should I hook up with it? Crane 1.5? I'm also wondering if this camshaft will be smog legal.
Next question: Will vortec heads bolt onto my car? If so, whats an average increase in horsepower? If not: what will be required to make them work?
With adding these to parts, should I grab a Holley AFPR? What about a Holley 52mm Throttle body?
Cars a 91 Z28 vert.
Thanks guys!
Old Feb 14, 2006 | 02:29 AM
iroc22's Avatar
For roller rockers, Comp Cams magnum full rollers are great rocker arm.
Im not sure on the smog legality for that cam.
For the Vortec heads you'll need a Vortec TPI baseplate, SDPC makes it, Im sure other outfits make it too. The 350 heads will carry somewhere in the region of 61cc-64cc depending on what casting you get, so compression shouldnt be a huge issue with the 305.
A VAFPR is a good idea, and along with that, Id recommend a custom PROM for that cam and heads, or else it wont run right, especially since you are running MAP (speed density)
Old Feb 14, 2006 | 11:00 PM
TeK-91z28's Avatar
Car: 91 z28 convert
Will this Vortec TPI baseplate allow me to run my stock intake still or will I have to upgrade like Steve said on VFB Mike?
VAFPR, whats that? Heads and cam aren't going on til Steve has his chip burning stuff.
Old Feb 15, 2006 | 01:30 AM
iroc22's Avatar
http://www.sdpc2000.com/catalog/1460...-Baseplate.htm
http://www.sdpc2000.com/catalog/1090...nder-Heads.htm
Both of those say they can use the stock runners. Siamesed runners are always better, but they will accept the stock runners.
VAFPR is just a vaccum referenced FPR. Vaccum referenced is better because it gives fuel pressure according to engine vaccum.
midge54
Dec 27, 2019 04:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
