305 to 383 TPI
Old Feb 15, 2006 | 12:11 PM
Derek8613's Avatar
Car: 1986 Trans Am
305 to 383 TPI
Im getting rid of my 305 TPI and putting in a 383 stroker. I would like to reuse my TPI if i can, but would it be a better idea to use something else?
Old Feb 15, 2006 | 04:19 PM
Skidmarks's Avatar
Car: 1988 Corvette Coupe
Axle/Gears: 2.59:1 IRS
A stock TPI systems barely flows adequate air to a 350ci motor. I would at least get a high flow base and runners.
1. High flow base runners = good street combo
2. Superram setup = good street/strip combo
3. Miniram set = better street/strip setup.
I'm sure there are other opinons, this is just my .02
(I only say the minram is better because it's revs a little higher then the superram)
Old Feb 15, 2006 | 08:00 PM
iroc22's Avatar
You could potentially reuse your TPI intake and just get higher lb/hr injectors, but like it was said above, the stock TPI unit just doesnt flow enough air. It can barely support a stock 350.
Orr89RocZ
Apr 25, 2016 08:28 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
