hp support of stock fuel pump
Old Feb 16, 2006 | 01:53 AM
89TA383M5's Avatar
Car: 89 TA
Engine: 413 TPI
Transmission: TKO 600
How much HP can the stock fuel pump support? Also what kind of cubic inches can it support? 425hp from a 413ci?
Old Feb 16, 2006 | 01:56 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Get a Walbro and play it safe. :-)
No thirdgen fuel pumps are really good for true higher hp applications.
later
Jeremy
Old Feb 20, 2006 | 12:07 AM
89TA383M5's Avatar
Car: 89 TA
Engine: 413 TPI
I'm going to upgrade my pump. My friend gave me a new AC Delco pump for a 454 truck. I was just wondering what the stock pump could support because my car seems to run lean on topend on the stock pump.
Old Feb 20, 2006 | 10:55 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I've heard about 400hp on a new unit but don't know for sure...I am still working on mine as we speak.
Old Feb 21, 2006 | 08:29 PM
Syn's Avatar
Syn
Car: 1989 Formula Ws6
Engine: 305 tpi
Transmission: 5speed
who knows alot about the stock pump?
do they have two outlets on the pump itself?
need one that does
Old Feb 21, 2006 | 08:57 PM
Shagwell's Avatar
Car: projects.......
89TA383M5 - that 454 pump won't be any better than what you have, and if it's not a 454MPFI pump, it won't even feed you.
Most people seem to like the Walbro. I know of a few w/ the Carter hipo. The Holley pumps seems to be a good one also. - I probably wouldn't go much over 400hp on the stocker myself.
the stocker/stock replacement type is single in/out.
Old Feb 22, 2006 | 12:33 AM
89TA383M5's Avatar
Car: 89 TA
Engine: 413 TPI
Thanks Shagwell for the info. Its a good thing I didnt put that pump in then. How much is a Walbro? I only see the Holley and Edelbrock ones on Summit. They go for $140-160. I'm pretty sure my car needs a pump since I have over 100k on the stock pump and the car was originaly a 305 and now its got a 413. Also you floor it and it starts to pull then it curves off. Also anytime I'm racing I can smell something "hot" and my exhaust gaskets keep burning out. Thats why I think I need to pump not to mention I sure hope my engine can put out over 400 horse which is the limitation of the stock pump acording to everone.
Old Feb 22, 2006 | 10:30 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I was told from multiple sources that the stock fuel pumps are only reliable to 270 hp. I bought my walbro from autoperformanceengineering.com. I wouldn't waste time putting in any other fuel pump than the walbro 255lph high pressure pump. For some extra bucks, you'll probably never change the fuel pump again.
Old Feb 22, 2006 | 03:13 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
What sources told you that? I haven't heard anything that low...i've been always told around ~400. I'd love to know some truth to this before I kill my pistons.
Old Feb 22, 2006 | 05:58 PM
Im pretty sure the guy that runs TBIchips.com said 270hp as well as TJ at Motorvation.
Old Feb 23, 2006 | 01:23 AM
3.8TransAM's Avatar
I wouldnt trust a stocker at the 400hp level, especially old and used lol
Go with a walbro 304 or 340 and be done with it.
Easiest and chepaest way to go.
A lot of the pumps u see for sale for 120-160$ are a reboxed Walbro anyhow :-)
later
Jeremy
Old Feb 23, 2006 | 04:41 AM
pimpflea's Avatar
Car: 1990 IROC-Z Coupe
Engine: 383
Im lookin to get a new pump, will this pump be a direct replacement for my stock one?
Walbro 255lph HP in-tank fuel pump (341)
I am building a ~450hp engine.
Old Feb 23, 2006 | 06:28 AM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Thats a great question, also while someone is checking into this, would someone know if you are running a 425/450hp application, is the stock fuel line big enough, because I have seen an article where they upgraded the fuel lines also because of the HP increase, and they showed how you had to mod the pump to put a larger feed line in it. Just currious, thanks.
Old Feb 23, 2006 | 09:39 AM
I'm really sure that pump will be a direct replacement. Just don't forget you will need a new pickup screen and possibly a new length of rubber hose. The hose must be rated for submerging in gasoline on the inside as well as the outside of the hose, because it goes inside the tank. www.autoperformanceengineering.com sells a complete installation kit for like $7. That kit includes both items above plus a few more things that you should replace too. My brother ordered the offset inlet for lt1 Walbro 255lph high pressure with install kit +shipping, it was $115 shipped.
Old Feb 23, 2006 | 11:48 PM
1bdbrd's Avatar
Car: 1991 Trans Am
i need some quick help about my Walbro 255lph pump i just got. im tryin to make sure wha ti got is what i really ordered (got it from ebay for an awesome price so i wanna double check before i put it in). mine mentions nothing about being any certain size, just has the Walbro name and logo engraved into the pump with some part numbers. anyone who knows for sure they have a 255, can you post the numbers on the side of the pump or maybe someway to tell the correct size?
Old Feb 25, 2006 | 12:47 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Ok so...anybody else have any information on how much these pumps will support or are we just going to say somewhere between 270 and 400?
Old Feb 25, 2006 | 10:02 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
My original factory pump was still supporting me at the 304RWHP level. However with my future mods in progress I changed it out to a AC Delco FE0114 fuel pump that is rated at 41 gallons per hour. That will support me up to at least 500HP.
Old Feb 25, 2006 | 10:26 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
http://www.racetronix.com/product/RX..._Pump_Kit.html
Why spend big $$ on an engine and then lean it out (ka-boom)over less than $200. Stock fuel pumps aren't up to the task, that's why there's a market for these.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
