any pic's of no a/c - air pumps?
Old Feb 27, 2006 | 01:36 PM
graphicideas1's Avatar
does anyone have photo os the engine bay after a a/s & air pump removal - looking to delete but would like to see how "clean" it looks before i go do it
Old Feb 28, 2006 | 10:07 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I don't have any pics at the moment showing the air pump removed, but it does look very clean without all that extra stuff.
Old Mar 1, 2006 | 07:50 PM
Rosco the Iroc's Avatar
Car: '89 IROC, '14 LTZ Burb, '18 H6 Outb
Engine: 355 TPI /w Vortec
Axle/Gears: 9 bolt 3.27
Here ya go!
Old Mar 1, 2006 | 08:02 PM
what did you do with your heater hoses on the passanger side?
Old Mar 1, 2006 | 11:00 PM
Zepher's Avatar
on my car, I think I am still running one line to the hardline that runs down the pass side engine bay up to the firewall and into the heater core, the other hose runs from the intake, above the valve cover and straight to the heater core.
Old Mar 2, 2006 | 05:37 AM
Nothing, there still there.
Old Mar 2, 2006 | 05:51 AM
how did you hide them?
Old Mar 2, 2006 | 06:17 AM
It's just the angle of the shot and red hoses on a red valve cover.
Old Mar 2, 2006 | 11:24 AM
AC's Avatar
AC
Car: Used to drive a camaro
Zepher, what did you do with your TB coolant hose? I notice its not connected. Did you also plug any vaccum ports on the TB? Couldn't notice in the pic.
Old Mar 2, 2006 | 01:42 PM
Zepher's Avatar
I did the TB Coolant Bypass mod when it had the TPI intake manifold on it.
I plugged up one vacuum line on the TB that is under the PCV line since it is no longer used.
Old Mar 2, 2006 | 02:17 PM
AC's Avatar
AC
Zepher....aaahh. Did you also ditch the charcoal canister or are you still using that?
Old Mar 2, 2006 | 08:11 PM
Zepher's Avatar
canister is gone as well.
Old Mar 4, 2006 | 01:49 PM
MdFormula350's Avatar
Originally posted by Rosco the Iroc
Here ya go!
clean engine bay
i like that air filter setup, i might try that also.
Old Mar 4, 2006 | 01:58 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
here is mine
Old Mar 4, 2006 | 02:43 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
looks good. I just finished installing my AC/Smog delete pullies an hour ago...lol
Old Mar 5, 2006 | 02:48 PM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
Engine: 305 TPI, '68 350 Olds SC'ed
Transmission: 700r4, 350 Streetfighter
Axle/Gears: stock, 3.42
TPI-Formula350-, that's a badass Formula you have. Let me ask you, does that Lingenfelter Super Ram Injection help alot? If so, how much more HP would that do for your motor? I saw a setup on ebay recently for $600. I was about to get it, but I didn't know too much about it.
Old Mar 5, 2006 | 04:54 PM
AC's Avatar
AC
MdFormula350, what did you do to your diverter valve? It definetly looks moved. Do you still have heat? Pics of that would be a great help.
Old Mar 8, 2006 | 08:29 PM
Here's a better pic-
evilstuie
Jan 9, 2020 08:29 PM
lakeffect2
Aug 23, 2015 08:44 AM
mcquigg
Aug 13, 2015 02:26 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
