Can I use 283/302/307/327/350 head gaskets on a 305
Old Mar 2, 2006 | 02:03 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I accidentally ordered a whole engine gasket kit for a 350 Chevy TPI engine w/ 1pc rear main. I have a 305 TPI engine. I got such an incredible deal on it, with name brand gaskets, that it is not worth shipping back. It has ROL extreme high temp head gaskets that are for 283/302/307/327/350 engines. I know the 305 has a smaller bore, and I will lose a small amount of compression by using a gasket with a bigger diameter cutout for the cylinder, but will everything seal okay? I assume it should be fine. The correct 305 gasket (felpro 8510pt) is 3.900 diameter, 0.041 thick. The gaskets I have are 4.005" diameter, 0.045 thick.
Old Mar 2, 2006 | 09:05 AM
V6camaroman's Avatar
I would have to say no. I ended up using regular napa premium brand 305 specific head gaskets when i rebuilt mine. i had ordered a set of metal .015 thin head gaskets because i wanted to gain some compression but i didnt like the extra quench area in the bore. there was just too much of a difference between the 2 sets.. so i say use 305 gaskets.
Old Mar 2, 2006 | 11:56 AM
Shagwell's Avatar
Car: projects.......
I've got 350 head gaskets on the 305 in my burban, but it's got 350 heads. - anyhow, yes it'll work just be giving up some compression, and leaving a place for carbon deposits...
Old Mar 2, 2006 | 01:02 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I am running the composite head gaskets for a Vette L98 on my LB9. no issues.
Old Mar 2, 2006 | 01:52 PM
Car: 2000 BMW M5
Ok cool thats what I figured. I will lose approx .15 compression with the thicker gaskets and larger combustion chamber rings, but I already have the composite gaskets. Grrrrrrrr! I might spring for the actual 305 gaskets, but at least I can use these if I have to.
Old Mar 2, 2006 | 06:13 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
I made the same mistake !
My world heads require 350 head gaskets, but I bought a 305 master kit. I had to go buy 350 head gaskets.
327, if your interested in the 305 (8510pt) gaskets, Email me, you can have 'em for the shipping cost.
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
