Is the MAF sensor the bottleneck???
Old Mar 20, 2006 | 04:44 AM
gta88 flamered's Avatar
Car: GTA 89
Transmission: TH700
I think this has been discussed a thousand times and even more....my question is: is the MAF sensor especially the screen the limiting value in a stock TPI system?
I've got the statement from someone who said: even if the cfm rate is big enough, the screen will make the engine harder to breath and therefore will reduce its liveniness...like trying to such through a straw compared to a tube.
I appreciate your comments.
Old Mar 20, 2006 | 06:03 AM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
The screen does limit air flow to some extent however for a stock TPI I dont think the MAF is where you need to be concerned just yet. The screens are necessary as they equalize out incoming air so the sensor can get an accurate sample. I suppose you could remove the rear screen - but do yourself a favor and leave the forward one on.
Old Mar 20, 2006 | 08:30 AM
Vader's Avatar
Using SCFM flow measurements at a PD of 28" H²O, you can compare the maximum flows of each intake component. There have been numerous threads regarding the ratings of each piece. And that's just the intake. What controls the intake flow rate are the cam profile, valves, and engine RPM.
Search the archived data and you may learn something about your TPI system - Whenever teh SEARCH feature is again enabled. .
Old Mar 20, 2006 | 09:38 AM
Guest
Guest
Posts: n/a
I think the MAF should be the least of your worries until you are making a fair bit of power. Whats done to the car, is it mostly stock? Leave it alone if so.
Old Mar 20, 2006 | 10:32 AM
zorronyellow's Avatar
Car: 89 Pontiac trans am
Engine: 350 5.7 Tpi
leave the screen alone it dosent make that much of a difference anyway i have mine in still and just the other day i was cleaning the air filter and there was dried up leafs on the screen dont know how the heck they got there but they did. i'd rather have the screens then the leaf in my engine
Old Mar 20, 2006 | 02:54 PM
Car: GTA 89
Transmission: TH700
Thanks for your feedback!
I don't want to remove screens of the MAF, my question was coming from a discussion with someone who told me that the descreened MAF will give better throttle response (even with a stock LB9)....
Old Mar 20, 2006 | 05:45 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
The stock runners and intake are the 2 most limiting factors. I'd go for those first. I'd also leave the MAF screen alone.
Old Mar 20, 2006 | 05:52 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally Posted by gta88 flamered
... is the MAF sensor especially the screen the limiting value in a stock TPI system?.
No and no.
Old Mar 20, 2006 | 07:42 PM
Vader's Avatar
This is an LB9? I thought you might be asking about an L98. With the 305, don't even give it a second thought. Start looking at the valve train first.
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
