fuel pressure regulator
Old Mar 20, 2006 | 10:37 PM
thirdgenner05's Avatar
Car: 89 t/a
hey guys, I have a new adjustable fuel pressure regulator from holley and a fuel pressure gauge inside of the trans am. Was wondering what a good roundabout fuel pressure would be on a 350 with stock injectors, free flowing exhaust system, ram air, cam and upgraded chip? thanks
Old Mar 20, 2006 | 11:39 PM
robert1's Avatar
Try 47 as a starting point, w/o vacuum that is.
Old Mar 21, 2006 | 05:29 AM
Car: 89 t/a
sorry I am still young and ask stupid questions...what do you mean by w/o vacuum? thanks
Old Mar 21, 2006 | 07:45 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
He means measuring the fuel press with the fuel press regulator vacuum hose disconnected (and plugged). Disconnecting the vacuum line makes fuel press rise by 4 to 6 psi. With the vacuum line connected, it should be close to 43 psi.
Old Mar 21, 2006 | 01:42 PM
Car: 89 t/a
thanks that helps out alot, I was pretty sure the regulator was messed up as it would be around 30 psi when first started and after a couple hours gradually move up to 60! then it would smell way to rich and smoke and all, thanks!
Old Mar 21, 2006 | 02:41 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
43.5 line off is the best setting for stock.
For temp fixes or if you are into your own prom tuning, experimenting with pressure can be of some benfit.
later
Jeremy
Old Mar 21, 2006 | 02:49 PM
sam's Avatar
sam
Mine TPI smells gas and when i last checked the PSI was fairly low. But shouldnt it smell more and run richer if i increse the pressure?
thanks,
Sam
Old Mar 22, 2006 | 07:05 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
If you increase fuel press, it will run richer in open loop. Once in closed loop, the ECM will keep the mixture at 14.7 to 1 provided the O2 sensor is working properly and the BLMs have not reached their limit.
Old Apr 19, 2006 | 12:18 PM
Car: 89 t/a
alright, well I am looking at getting new injectors anyways as well to accomodate for the custom chip that Im putting on the t/a. I have heard ford rates different fuel flow settings? if I put 24lb injectors on with a tuned chip then what should my fuel pressure be at? probably lower than the 43 without the line because stock was 22lb and these are 24's? thanks guys!
Old Apr 19, 2006 | 12:25 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
So whats the point of an AFPR?
Old Apr 19, 2006 | 12:45 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
good point..... that doesnt make sense to me either
hey i know this is off topic, but i just checked out the pictures of IROCThe5.7L's camaro and theres a pic of it in a gas tank, the prices are like 1.50 a gallon lmfao. how long ago was taht????
Old Apr 19, 2006 | 02:37 PM
Car: 89 t/a
anybody have an answer to my question? haha
Old Apr 20, 2006 | 11:56 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
With a custom chip, you can lie to the ECM telling it the injs are smaller or larger than their actual size.
If you want to run lower-than-stock fuel press, you tell the ecm that the injs are smaller than they really are. The ecm will hold them open longer so you wind up with the right amount of fuel.
If you want to run higher-then-stock fuel press, you do the opposite.
(On my chip I have the fuel inj size set to 26.5 lbs even though I actually have 24 lb inj installed)
The correct inj size on the chip is found by trial and error. You set the inj size, drive the car, note where the BLMs are at, modify the fuel inj size (on the chip), drive the car, note the BLMs, make another inj size adj, drive the car, and so on. If you adjust the fuel press a significant amount, you'll need to start the process all over again.
Some people (myself included) like to run their fuel press a little higher than stock to improve fuel atomization. There are limits however. Running fuel press over 50 psi (on a tpi car) is really hard on the fuel pump.
Replacing the 22lb injs with 24 lb injs will make the eng recieve more fuel than the ecm planned for. By adjusting the fuel press down you can make the eng recieve the correct amount of fuel, but lowering fuel press will effect the fuel atomization. That's why you need a custom chip when installing larger injs.
The BLMs are commonly misunderstood. Here's a link to a post I responded to that explains it a little better and gives some additional info on ECM tuning theory.
https://www.thirdgen.org/forums/diy-...now-werid.html
The purpose of the AFPR is just to give you another **** to turn for tuning.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
