TBI to TPI
Old Mar 20, 2006 | 11:28 PM
CamaroRog's Avatar
Car: 91 RS
Engine: lo3 305 :(
Transmission: 700r-4
Axle/Gears: 3.42 - Torsen Posi
TBI to TPI
I have a 91rs 305 w/ TBI, and i am looking to convert to TPI when i drop in a 350 soon. Reason being, that my stock TBI is a little messed up and on the way out the door, and ive heard TPI is easier to tune. First of all, can I use my stock TBI harness, or would I be better off taking the complete TPI harness from a junkyard car, or modifying my current one? Also which heads will boltup to the TPI unit, is it possible to hook vortecs up, l98's? Will i need special runners or manifold for that?
Thanks for any and all help in advance.
Old Mar 21, 2006 | 10:22 PM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
im in the process of the same swap except mine is an 89....i got a rebuilt 350TPI pretty much complete and am just about done....im sure theres a lot of things you will have questions about so dont hesitate to PM me.....as for your harness, if your existing harness is still in good shape then talk to a guy named mike.....his email adress is mike@eficonnection.net.....he converted mine at a very reasonable price and did a great job.....his member name on here is S10wildside.......let me know if you have any questions...good luck
Steve
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
