Safe to run in closed loop?
Old Mar 23, 2006 | 06:00 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Just wondering its a bit buggy, but runs perfect in closed loop id prefer to run it like this until i can repair it
Or is it bad for the motor?
Old Mar 23, 2006 | 07:15 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its suppose to run in closed loop.
Old Mar 23, 2006 | 08:51 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Im sorry must have confused myself, Open loop ( speed density mode)
Old Mar 23, 2006 | 11:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
You converted your 87 MAF car to speed density?
Old Mar 24, 2006 | 07:41 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
give more details.
What u did and why u did it and the exact setup would help instead of endless guessing.
later
Jeremy
Old Mar 24, 2006 | 02:02 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
No no, its an original MAF car, What i mean is lol
When certain sensors are unplugged the computer will go into closed or open loop?
Reading of stored engine data, and the 02 sensor
Like i said, For example if i unplug the maf sensor, It runs a ton better, With the maf sensor plugged in i have problems and since at the moment i dont have any tools ( in my shop (tech school) i would like to run it in this mode until i can diagnose it myself or send it to the garage
Old Mar 25, 2006 | 09:44 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
The car will run so you can drive it with the MAF unplugged?? hummmm
Old Mar 25, 2006 | 10:08 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
If the car does not run with the MAF plugged in, then what do you think is the problem? Get a new MAF.
Old Mar 25, 2006 | 11:14 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
The car should run like crap since it cant monitor the incoming air and temps. atleast in my experiance they have.
Old Mar 25, 2006 | 11:44 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
Its alot more then just the maf, Its alot of things that at the moment i dont feel like dealing with until i have the time ( maybe in a month) to fix, Without the maf plugged in, instant throttle responce, but a bit of a wierd idle, thats it
With it plugged in crap throttle responce, seems to run out of wack, Like i said dont have the time atm to do anything about it so i was wondering if it was safe to run it without it plugged in
But for those who wanna give my problem a shot keep in mind i dont have any tools with me atm
Small vacuum leak in a egr line,no vss, was swapped from a 700r4 to a t-5, new tps, until operating temp, Give it gas boggs down then pops in the intake till it hits that rpm ( keep in mind only with it depressed for a bit, if i give it a quick goose its fine) also ohmed the injectors before i Moved my tools, all 16.0 or 15.8 15.7 etc, Also.. one of the fuel lines broke the other day, ( not driving atm but getting it all registered soon) this fuel line was the fuel feed line from the tank, Im trying to find an oem fitting line only place i see one online is fbodymotorsports. and well i heard they suck so Im thinking of just sending it of for a full checkup at the garage anyhow
Old Mar 25, 2006 | 12:32 PM
DON 88T/A's Avatar
The car will run rich without the maf plugged in since the ecm has no clue what is really happening so it adds fuel to be safe...it is okay to run it forawhile with the maf unplugged but I wouldn't do it any longer than you have too...replace the maf first,then reset your ecm,then tackle your other problems...if the idle is having problems look for any vaccum leaks,and check the IAC...these two things usaully are the culprit behind most idle problems.
Old Mar 25, 2006 | 01:26 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Thankyou very much for the answer, Im guessing itll only be running like that for about a month, then it will be repaired
customblackbird
Aug 15, 2021 10:16 PM
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
