electronic spark timing circuit
Old Mar 26, 2006 | 07:38 PM
mikesz1984's Avatar
Car: 1984 z28
Does anybody know where this is located, i pulled a code 42 out of my computer, and i want to know what to do to fix this. I would do a search, but my control panel doesnt seem to have it anymore.
Old Mar 26, 2006 | 10:19 PM
Vader's Avatar
Presuming you installed the 1987 ECM with the '87 L98, the ESC should be a separate unit bolted to the firewall accessory bracket near the brake booster:
Old Mar 27, 2006 | 05:03 AM
mikesz1984's Avatar
Car: 1984 z28
thanks vader i know exactly where that is.
Old Mar 27, 2006 | 06:28 PM
mikesz1984's Avatar
Car: 1984 z28
well i tried an experiment tonight, i replaced the computer with a 305 tpi computer i had here, and the code disappeared. So i took the memcal out of the 350 computer and then reinstalled it back into the 350 computer, and put it back in the car, and a different code came up. It was code 34, Mass airflow sensor low. Could this actually be a computer problem i am chasing, and not a sensor problem
Old Mar 29, 2006 | 11:28 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
Hello,
Maybe you guys could help me identify the three relays behind the booster on a 90 IROC. Mine are all snaped on one bracket. My car has no maf, it does have a map sensor on the intake. Any help would be awsome. My manuals do not cover theese parts. in advance!!!!
Mark
Old Mar 29, 2006 | 11:38 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Two are fan relays and the other is the fuel pump relay on the 90.
Old Mar 29, 2006 | 03:22 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
3.8TRANSAM-
MARK
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
