TPI Swap
Old Mar 29, 2006 | 08:08 PM
camaroracer016's Avatar
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
TPI Swap
Well since the search is down, i guess il just post the question. im About to do a TPI swap on my 84'. I would like to know all the things i would have to do. That car origionally had a 305 CCC. Im looking to buy a new harness, which would connect to the IP harness inside the car for power, SES, etc. Any suggestions on what to do! Your help is greatly appreciated!
Old Mar 30, 2006 | 06:35 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
WOW , it's a pretty big question. You need to use the search when it's back up and running. I also recomend getting a book called the "TPI swappers guide"
Old Mar 30, 2006 | 06:39 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
tpi swappers guide doesnt really show you a lot, do searches here, you need to do all the wiring, the input harness is basically power for the ecm/injectors/vss ect, also do a good job on the fuel system, intank fuel pump and high pressure lines from gas tank to tuned port fuel rail, i did this swap over the winter. i originally had a ccc carb.
Old Mar 30, 2006 | 07:28 PM
buwamd's Avatar
Car: 84 v6 camaro
Engine: 355 tpi
hi i did a similar swap in the fall this will help
Chevythunder
also get ahold of the guys at painless wiring and ask them exactly what you'll need, and the swappers guide is highly recommended. good luck
Old Mar 31, 2006 | 11:00 AM
Stingray69's Avatar
Car: '78 Camaro
Engine: '87 TPI
Axle/Gears: '81 WS6 Disks-3.90:1
There are a few companies making after-market harnesses.
I used Bill Howell's harness. It was for a stand-alone setup, but he used to, and probably still does, alter factory harnesses from OE computer cars. Mine was for a '78, with no computer at all, very easy to install. He was one of the guys that developed it for GM, then he went into business for himself after he retired. He was about the first guy offering transplant harnesses.
Howell Engine Developments, Inc. Home Page
There is an installation page in .pdf that may help you
Google search Bill Howell TPI.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
