What cam would be good for my application?
Old Apr 12, 2006 | 12:40 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Ok- I need a new cam- mine is junk lol!.. I am wanting to go with something that would be the equivalent of a "hot cam" and still give me low end torque and power.. I was looking at a lunati hyd. flat tappet cam( b/c i already bought lunati hyd. flat tappet lifters)
The lunati specs are as follows:Brand: Lunati
Product Line: Lunati Hydraulic Flat Tappet Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,000-5,500 RPM
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 224 int./224 exh.
Advertised Intake Duration: 290
Advertised Exhaust Duration: 290
Advertised Duration: 290 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.460 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.460 in.
Valve Lift with Factory Rocker Arm Ratio: 0.460 int./0.460 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Would this be a good cam to go with, or does anyone have any other reccomendations?
My engine specs are in my sig. w/a 9.5:1 compression ratio forged flat top pistons, Vortec Large port heads, High flow TPI stuff and what not..
Thanks!!!
Old Apr 12, 2006 | 01:49 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I am not sure of the I/E ratio of them heads but , with most GM heads they have a weak exhaust so I would recomend a split pattern cam at the least, to make up for that bias.
You got the flow numbers on them ?
Old Apr 12, 2006 | 03:39 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
No i dont but the heads are Jegs PN:809-12558060
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
cstrobel65
Aug 15, 2015 10:19 AM
anesthes
Aug 8, 2015 09:37 PM
