Cold start injector Ohms
Old Apr 13, 2006 | 07:52 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Anybody know what I should have for cold start injector ohms? I checked it & I get 4.1 Ohms. Is this good or should it read higher like the other 8, I got 16.5 to 17 on those. 87 305 TPI.
Old Apr 26, 2006 | 09:54 AM
Vader's Avatar
4.1 is good.
Old Apr 27, 2006 | 08:40 AM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thanks I talked to rich at cruzin performance & he said it sounds like the injectors might be leaking> I will get a fuel pressure guage & check leakdown als will buy node light to check if injectors getting signal. The car runs after hard start but I want to see if injectors are firing as soon as I try to start the car. I will also check to see if plugs are firing right away. I want to make sure it's not something simple like a sensor (cts) or a relay. I will also check for gas in the fuel regulator. I hope this will cover all the bases!!!
Old Apr 29, 2006 | 08:54 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thanks for the help. Worked on it yesterday and am pretty sure cold start sensor is messed up. Starts fine if cold start is disabled. Will replace sensor & hope that it was that easy!!!!
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
