Removing Emissions
Old Apr 13, 2006 | 08:06 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Removing Emissions
Ok so Im rebuilding my motor, and In the process of taking the engine out I took off the AIR tubes, the rubber hose runs to some sort of black box that when I took apart had two servo looking ("THINGS") and the hose ran to the smog pump. So my first question is what is that BLACK box that connects to smog pump and AIR tubes. Second question what happens if I just re-assemble the engine without AIR tubes, smog pump, and the BLACK BOX ?
Will it throw codes ??
Old Apr 14, 2006 | 12:00 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
i yanked my smog pump, and all the tubes for my headers with no ill effects. I haven't had any trouble codes either. You will need to get a 2" shorter belt if you are running a serpentine, and you'll need route the belt a bit different. There is an article in the Tech section of this site where i learned it. Its under "smog pump delete" i think.
I also have it on my webpage on my link....
Old Apr 14, 2006 | 12:20 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Yea I've checked out the article on how to re-route the belt. But Im concerned about that black box that has some wiring going to it thats connected to the smog pump.
Old Apr 14, 2006 | 12:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
isnt that box the thing that supplies air into the AIR tubes?
Old Apr 14, 2006 | 02:50 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Well it appears that the box has a solenoid controlled valve, but Im not sure. The only reason I think it might have a solenoid is it might only operate during "closed loop". But regardless I want it out for good. Its annoying and it clutters my engine and makes it hard to access vavle covers. I just wanna know if I leave out ; smog pump , AIR tubes, and "black box" will I have a strange running motor or any unfavorable effects ?
Old Apr 14, 2006 | 06:36 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
BUMP
Old Apr 14, 2006 | 07:51 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Be sure to yank out that nasty catalytic converter or it'll cause problems down the road. Get a test pipe to replace it or have one welded in its place, or if your cheap like me hollow it out. A clogged converter will do a lot of damage.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
