Code 51 help needed
Old Apr 14, 2006 | 02:31 PM
buffaloman's Avatar
Car: 1989 Firebird Fornula 350
Engine: 350 L98 / NOS
Transmission: 4sp Auto
Code 51 help needed
Well all most didn't make it back home. Stock formula 350 1989. I pulled the code and it is 51. I have no clue how to even start to fix. Car seems to run fine now but when that code 51 went off it wouldn't stay running wery long and popped in the exhaust. Exhaust is all new. Any body help.
Old Apr 15, 2006 | 08:44 AM
buffaloman's Avatar
I found this.
Trouble Code 51 indicates that the ECM sensed a fault in the MEM-CAL. On power-up, the ECM does a checksum of the MEM-CAL to ensure the MEM-CAL integrity is good. If the calculated sum does not match the sum in the MEM-CAL, the ECM will hardcode 51 and enter Back-Up mode, since the ECM cannot know where in the MEM-CAL the fault lies.
Code 51 is set when:
- the actual MEM-CAL checksum does not match the value in the MEM-CAL
Possible causes include:
1) Incorrectly installed MEM-CAL module
2) Defective MEM-CAL module
3) Defective ECM
Old Apr 15, 2006 | 09:15 AM
Vader's Avatar
That is the correct definition. Are you using a custom program? Have you had the ECM and/or MEMCAL removed recently?
Old Apr 15, 2006 | 09:21 AM
buffaloman's Avatar
Stock Prom and never had the EMC out. The car seems to run fine now. But I don't want to take it on the road and get stuck.
Old Apr 15, 2006 | 12:04 PM
STIFFLER's Avatar
I have code 51 that won't go away.. I have changed the memcal,prom,ecm and checked the grounds.. nothing seems to work. Anyone have any help?
Old Apr 15, 2006 | 12:09 PM
buffaloman's Avatar
When I got the code 51 car wouldn't stay running and when it did and I hit the gas it stop like to gas.
Old Apr 17, 2006 | 10:50 AM
buffaloman's Avatar
Any help Please.
Old Apr 19, 2006 | 09:10 AM
buffaloman's Avatar
Help!!
Old Apr 19, 2006 | 11:33 AM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
mine had the same thing, and it ended up being the prom.
maybe switch out the ECM, with one known to work, and see if that works.
good luck,
joe
Old Apr 19, 2006 | 01:31 PM
buffaloman's Avatar
OK, I just ordered a new prom $44.00
I'll give that a try and get back to all.
Old May 2, 2006 | 03:19 PM
buffaloman's Avatar
Got the new prom today and will install. I have never had the computer out so if this repairs it I will post.
Old May 2, 2006 | 05:55 PM
STIFFLER's Avatar
Ok I awaiting your results...
Old May 2, 2006 | 06:08 PM
buffaloman's Avatar
No help. Got 1/2 mile down the road and the same thing. Made it back and went and ordered a new computer.
Old May 3, 2006 | 09:32 PM
buffaloman's Avatar
Got the new computer. Will install Thursday.
Old May 4, 2006 | 12:03 PM
buffaloman's Avatar
New $77.00 computer installed and problem repaired. It wasn't the PROM chip, it was the computer it self. Hope this helps others on this code 51 problem.
The core for the computer at Advance Auto was $60.00 , which I took the old one with me and had to remove prom chip and side studs as the new one didn't come with these items. Now I can drive my 89 formula 350. GREAT
lee01
Apr 9, 2016 01:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
