what makes an engine retard the timing when reving??
Old Apr 15, 2006 | 02:44 PM
87camaro kid's Avatar
Car: 1987 Z28
when i was looking at the timing of my car with the EST wire disconected my timing was at 4* advanced or BTDC and when i would give it gas it would go to 2* before and then almost to 0* TDC i thought it would advance and go from 4* to 6* and so on?
this is a picture of what im talking about
Attached Thumbnails what makes an engine retard the timing when reving??-timing1.jpg
Old Apr 16, 2006 | 01:27 AM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
Guess the question would be is the car running right?
Got good power?
I am having a serious timing retard problem.
I don't know what in the crap is going on with mine.
The knock sensor can cause the timing to retard if it picks up noise, detonation, or a knock.
I've got mine grounded out through a 3.9k resistor and it is still retarding.
Old Apr 16, 2006 | 05:49 PM
Car: 1987 Z28
i have pretty loud exhaust and i have a cut out could that cause it and how can i fix that?
Old Apr 16, 2006 | 06:00 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I think this is normal from everything I have seen. My car drops a few degrees right off idle too. it has always done this and it runs fine. My truck does it too. hopefully someone who knows more than me chimes in here.
Old Apr 16, 2006 | 09:29 PM
Car: 1987 Z28
i have no idea, i dont no if this would have anything to do with it also but i had to retard the timing from 6* to 4* because the car would surge at crusing speeds i guess from being to lean so could the o2 sensor be bad or tps or something is wrong with the vacuum
Old Apr 17, 2006 | 11:50 AM
Vader's Avatar
With most stock (and custom) programs, the timing tables do not change timing in a linear fashion. It generally starts relatively high at low load values, then drops off as calculated engine load increases. One RPM catches up and load decreases, the timing increases again. This is usually appropriate, and just one reason EFI systems have inherent superiority comapred to a mechanical/vacuum distributor advance scheme.
A vacuum advance can try to emulate this necessary drop in advance under load, but there is always a compromise in either initial timing, mechanical advance limit, vacuum advance curve, where they cross, or total advance. Being able to plot it out on a table with no necessary relevance between engine vacuum/RPM/load is far more flexible that spending half a day playing with advance weights, weight cam tailoring, weight sppring rate and pull, vacuum spring tweaking, and ending with only the best compromise on a distributor machine. It's still a compromise.
Old Apr 18, 2006 | 09:57 AM
Car: 1987 Z28
does that mean my car is acting normal then?
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
