Need some wiring help with TPI swap!
Old Apr 17, 2006 | 12:25 AM
toddztoyz's Avatar
Car: 86 Monte Carlo SS
Engine: 5.0 liter High Output w/ TPI
Transmission: built 700R4 Auto
Axle/Gears: 10 bolt 3.73
I am installing TPI on my 1986 Monte Carlo SS. I am using the Painless Performance Harness #60102. This is the 86 to 89 MAF system with 9th injector.
questions
1. The MAT (manifold air temp. sensor) located under the upper intake plenum has the plug cut off of it by the previous moron that tried to hook this system up. The wires are TAN, and Black. Which wire goes to which side of the connector as shown in the photo below?
Old Apr 17, 2006 | 09:50 AM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I may be wrong, but I think that since the sensor is just a variable rate resistor that it shouldnt matter which way you hook it up. You can check TPIParts.net and Ebay to see if you can find the connector and where the wires are placed based on the position of the tab on the connector.
Old Apr 17, 2006 | 11:47 AM
Shagwell's Avatar
Car: projects.......
...it doesn't matter...just resistance. - While you're there, pull the sensor, plug the whole and put the sensor in you air intake duct. Just another one of the TPI "free mods".
Old Apr 17, 2006 | 12:47 PM
toddztoyz's Avatar
Thanks guys! That is what I thought, but I just wanted to confirm this.
midge54
Sep 2, 2020 07:13 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
