MPFI vs TPI
Old Apr 18, 2006 | 07:58 PM
Striker25's Avatar
MPFI vs TPI
Can someone explain the difference between MPFI system & TPI system and the pro's & con's of both!!
Striker
Old Apr 18, 2006 | 08:11 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
as far as i know mpfi only came on the v6 & tpi on the 305 & 350 on the 3rd gens anyways.tpi has tons of low end torque but wont support high rpm's i know nothing about mpfi.
Old Apr 18, 2006 | 11:23 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
TPI is a type of MPFI, they are not different things you can "compare". MPFI = multiport fuel injection. TPI is this. TBI is not MPFI, for example.
Old Apr 19, 2006 | 10:43 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
TPI = tuned port injection, one injector per cylinder, TBI does not have this
Old Apr 19, 2006 | 11:08 AM
Shagwell's Avatar
Car: projects.......
MPFI is NOT TPI by true deffinition.
Multi Point sytems actually fire each injector individually, in time with the cylinder. TPI systems are "batch fire" - all injectors fire at the same time.
If you want true MPFI, you have to run either am aftermarket set-up or the Cadillac ecu. The LT1 ecu is also "sequential"(MPFI) but only up to like 3000rpm.
- All of this has been discussed several times....thats how I learned....
Old Apr 19, 2006 | 11:35 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
How I read it . TPI IS MPFI ....it's just not SFI ( sequencial fuel injection) <--- whic fires it at a different port at different times . Where TPI is a batch fire multiport setup ...just not sequential.
Old Apr 19, 2006 | 01:29 PM
Car: 2000 BMW M5
Yeah, multiport is what is says, multiple ports, ie 1 injector per cylinder. I will still say TPI is multiport. Sequential multiport is a different type of multiport than batch fire multiport.
Old Apr 21, 2006 | 01:19 AM
iroc22's Avatar
TPI is a MPFI system.
LT1 is a SFI system.
And the LT1 ecu goes into batch fire ONLY at full throttle; it operates the injectors sequentially at all part throttle positions for driveability and emissions.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
