egr valve
Old Apr 19, 2006 | 12:10 AM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
egr valve
Ok this may be redundant, but i can't sesem to find anything on it. I pulled a 1987 tpi off the ta- do I have to use the egr valve for it to work properly when reinstalled. Keep in mind that I will be using the stock 350 chip and I do not have to worry about emmisions.
later and thanks
rk
Old Apr 20, 2006 | 02:22 AM
rezinn's Avatar
No. But it wouldn't hurt you to. You'll probably also set a code without it connected, and you will need to account for some differences between the 350 and 305 fuel systems since you're using a 305 tpi and a 350 chip and ? motor.
Old Apr 20, 2006 | 02:31 AM
Rick King's Avatar
Car: 1987 TA
thanks for the info--it wil go on a mild 350
later and
gB
rk
Old Apr 20, 2006 | 02:36 AM
rezinn's Avatar
If you're using a 350 chip you're going to need 350 injectors unless you reprogram. I believe the knock sensor is also different for that block. I can't think of anything else this late.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
