WHAT THE???
Old Apr 21, 2006 | 06:54 PM
2badcams's Avatar
Car: a 91 rs convertible and a Iroc z convertible
Engine: 305 tbi, and 350 tpi
WHAT THE???
i went to the junkyard and found a fire bird with a H.O motor. the engine had a intake manifold with two carbs accross or diagonal from each other. is this stock on the H.O's>? i was thinking of picking that up, is that better or not than the tpi?
Old Apr 21, 2006 | 06:56 PM
Tims 88gt's Avatar
Car: Mustang
Engine: 302
Transmission: 5spd
Axle/Gears: 8.8 with 3.73
not that i have even seen.
Old Apr 21, 2006 | 07:03 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
intake
cross-fire intake ,early models like 82,corvettes had same stle
82-84 cross-fire injection ram air unit
Old Apr 21, 2006 | 07:15 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Yup. CF. RUN!!!!
Old Apr 21, 2006 | 11:28 PM
eflores's Avatar
Car: 91 z Clone
Engine: 6.4l LSX
Axle/Gears: s12 3.73
five gallons of gas and a road flare...dump gas on motor light flare throw on motor run far far away
Old Apr 22, 2006 | 08:40 AM
DuStangz's Avatar
Car: 79z28 91z28 89 irocz28
Engine: 383 350 tpi 350 carb
Transmission: th350 700r4 700r4
Axle/Gears: ford 8.8 3.73 ? 3.23
the set up is worth some bucks to a guy looking for it ...you dont find those intakes to often i'd grab it and hang on to it !!!!!
Old Apr 22, 2006 | 09:03 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Crossfire is junk.
Old Apr 23, 2006 | 09:44 PM
zorronyellow's Avatar
Car: 89 Pontiac trans am
Engine: 350 5.7 Tpi
Say why its junk!! The motor itself i would buy and keep it if you get it for dirt cheap because there is people out there that will pay good money for that. But as for changing out ur eng. for that crossfire no way buddy the TPI 350 L98 was the eng. that replaced the old crossfire model and they have more problems then the tpi
Old Apr 23, 2006 | 09:48 PM
turbosbox's Avatar
Car: 88 TPI formula
Engine: L98 Vortech
Transmission: TH700r4
not worth much
I read the intake ports were too small to make any decent power. On the manifold at least. Not sure of heads. It looks cool. I was thinking of trying to put carbs on it like the old DZ302 Z28 crossram. Figure that is what they were trying to inspire with it.
Maybe putting a weiand action plus on it and a four barrel would make it drivable?
