TPI year?
Old Apr 23, 2006 | 08:22 PM
bizones's Avatar
TPI year?
is there any way to tell what year my tpi came off of?? im pretty sure it is an 88??
Old Apr 24, 2006 | 02:05 AM
iroc22's Avatar
85-86 have the two middle intake bolt holes (that bolt to the heads) at the same angle as the outer ones.
87-89 have different intake bolt holes for the two middle ones on either side.
90-92 are the same as 87-89 except there is a MAP sensor bolted to the manifold.
And I dont remember which earlier manifolds had the 9th cold start injector equipped.
Old Apr 24, 2006 | 10:29 AM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
the 9ths came on the 88's and older i thought
Old Apr 24, 2006 | 02:11 PM
SKFengineer's Avatar
Car: '87 IROC (TPI 350), '01 Corvette, '
Engine: '90 Corvette 350, blueprinted and b
Transmission: 700 R-4, with stage 2 shift kit
My '87 has a ninth injector so 8upAford's reply sounds right.
Old Jul 26, 2006 | 11:29 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
I did a search and it found this thread. I'm pretty sure my engine came out of an 88 because It has serpentine and my car is an 87, but it still has a Cold Start Injector. Any other ways to verify its deffinatly an 88? 89 Didnt have cold start, and 87 didnt have Serpentine. SO I think i narrowed it down to 88, but wanna double check
Old Jul 27, 2006 | 09:25 AM
8UpAFord's Avatar
Car: 1988 Corvette
Just don't buy TPI motor 89 and older. Find one newer. Nothing wrong with a 9th they just get in the way when trying to mod up your intake or if you need to replace it. if you have a choice DONT GET ONE with a9th.
good luck.
Old Jul 27, 2006 | 05:23 PM
Car: 95 Z28
I bought the car with an 88 in it already. I dont mind lol, its not stock and my last cars have been V6 so I'm happy :P
Old Jul 27, 2006 | 06:21 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
1985-1988 Cold Start.
1989 No cold Start , MaF
1990-1992 No cold start. Speed Density
LT1Formula
20
Nov 14, 2015 12:02 AM
69 Six Pack
Oct 5, 2015 07:51 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
