Will Large Port Vortec Heads Fit
Old Apr 24, 2006 | 05:32 AM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
I was looking at the Large Port Vortecs on Jegs.com JEGS High Performance - GM Performance Parts Cast Iron Large Port Vortec SBC Heads
and was wondering if they will fit on the stock TPI setup. It says that the intake mounting holes are for both the early model 6 bolt and late model 4 bolt. Does anyone have any experience with these?
Old Apr 24, 2006 | 08:59 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
They probably still have the raised intake ports, so a stock TPI base probably won't match up very well... There's not a lot of meat on a stock base to work with either, so I dunno...
Old Apr 24, 2006 | 02:17 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
With the stock TPI base , you will be cutting off some of the area
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
