Caburator to tpi swap
Old Apr 25, 2006 | 05:16 PM
Camaroman P's Avatar
Car: 1998 Z28
Engine: 350 lt1 sued up
Transmission: 460le
Ihave a1983 z28 with a 92 rs 305 engine but with a holley carburator I am converting over to tpi speed density where do I start with the fuel tankoh and I heard I can just swap the fuel tank out let to one out of a iroc forfuel injection is it that eazy or what
Old Apr 26, 2006 | 09:41 AM
Vader's Avatar
You will need a TPI fuel pump in the tank or externally mounted. Whichever route you take to get 44PSI of fuel pressure to the TPI system is up to you. Since you have to remove the tank to exchange one from an IROC, it may be just as easy to mount a new TPI pump in your old tank and not bother with the used tank. Make sure you provide a fuel return line and a vapor vent line in addition to the fuel supply line.
Old Apr 26, 2006 | 11:41 AM
Car: 1998 Z28
Transmission: 460le
Carburator to tpi swapp
What about the wire harness will it be an easy swapp or do I need to change the fuse box
Old Apr 26, 2006 | 02:27 PM
toddztoyz's Avatar
Car: 86 Monte Carlo SS
Engine: 5.0 liter High Output w/ TPI
Transmission: built 700R4 Auto
Axle/Gears: 10 bolt 3.73
The engine wiring harness is completely seperate from the car harness for the most part. You will need the complete harness, computer, throttle cable, and the tranny kickdown cable to do your swap. The engine harness will cover all aspects to run the fuel injection. The car harness you already have runs your gauges lights and most everything else not related to emissions or fuel computer.
The throttle cable for the tpi is longer and so is the tranny kickdown. So far on my Monte SS, it has been pretty straight forward. I am using the painless wiring harness with the 86-88 Tpi with mass air and the 9th injector.
Old Apr 26, 2006 | 03:08 PM
Car: 1998 Z28
Transmission: 460le
so I don't have to switch the fuse box or any thing inside the car under the dash I got the throttle cable and the kicke down cable
Old Apr 26, 2006 | 03:39 PM
toddztoyz's Avatar
You should be able to tie the two harnesses together where the dash harness plugs into the computer harness. The dash harness is you ALDL, Brake switch for the TCC converter, and the power from the ignition.
One issue that may come up because you are using a speed density system is the VATS. This is the security that GM put into the Vettes and TA's and some Camaro's that will give you fits because the system looks for the resistor in the key to allow the car to run. You may have to get a custom chip burned to eliminate the VATS. Painless wiring and some others offer a chip that eliminates the VATs.
Old Apr 29, 2006 | 08:54 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
PAINLESS or have someone modify your carb harness to accept the tpi.
New harness vs spliced- I would go with PAINLESS all day.
Old May 1, 2006 | 09:21 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
I converted my 86 IROC-Z from Carb to TPI. It was some work but worth it. I highly suggest to pick your parts wisely, it will cost you though. You only need the pass side harness like stated. It may be easy to find an un hacked 89 or newer harness. I would suggest the painless wiring harness as well, about 3 bills. You HAVE TO GET a GM service manual for what ever year injection system you want to install, it has every color coded wire and exactly every step for tuning and trouble shooting. Since my IROC is an 86 I went with an 86 TPI system and got the 86 GM service manual from a buddy and it made it MUCH easier. I suggest sending your injectors into Rich at Cruizin Performance for a full cleaning. Mine were completely clogged and would have made for a huge problem the first time I tried to fire it up. Next thing, the intake and runners - go ahead and do yourself a favor, buy the large tube runners and big mouth base! It will cost you around 7 bills for those two pieces but you will appreciate it when your engine still has power over 4000 RPM. Problem of stock intake manifold and runners! I will replace my stock ones out in the near future to allow my car to run longer. Like stated, new TV cable, accelorator cable, and misc odd and ends. I did an engine rebuild, tranny rebuild, serpentine belt assembly install and carb to TPI swap all in one shot and it took me forever. I could go on forever and forever but feel free to ask me anything you might want to ask and there is another very knowledgeable board member I converse with a lot that used a VSS style set-up as well. He'll probally chime in on this thread soon. Tony
Old May 3, 2006 | 08:02 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i would focus on a good fuel system, from the tank to the fuel rails, i'm not sure if your motor is stock or not, but you will need a custom chip with vats removed, if your motor is modified at all you may be looking at additional programming
i used a stock harness for my setup, you dont have to change the fuse box but if you want plug and play you would have to, otherwise you have to tie in to the cars harness from the engine harness, for the tcc injector power ecm power vss ect, you definately need a service manual and a lot of money for parts.
any other questions ask away.
Old Jul 4, 2006 | 12:39 PM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
Not to hijack, but would a fuel-injected v6 interior harness work as a plug and play unit?
Old Jul 4, 2006 | 04:48 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I ran a Holley Inline External pump on my swap since I didn't feel like messing with the tank at the time.
Old Jul 4, 2006 | 06:50 PM
Car: 1986 Iroc-Z
My inline fuel pump is so damn loud that I am going to do the proper install of the intank real soon.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
