water pump Q
water pump Q
Hi guys I'm new to the forum. I'm putting a TPI in my wrangler and was wondering what size water pump it takes? Short, or long?
I will be running the stock serpentine system setup on it from a 89 firebird.
Mike-
Mike-
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
typically its long and reverse rotation.
but what ever fits you app, long/short wise you can use, but then if you use short, the belts wont work, unless you used a vette setup??
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
