Fuel Pump Bypass wire?
Old Apr 26, 2006 | 04:18 PM
JBert's Avatar
Car: Looking
Can anyone tell me where to find the fuel pump bypass wire on an 88 305 TPI Iroc? I've been told several times that it is a tan wire that should be hanging over by the heater box. All I've found was a tan wire with a weatherpack connecter in between (connected). Any pics?
Thanks!
Old Apr 26, 2006 | 04:51 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
I don't remember this, but this is what I found.
The Fuel Pump Prime Connector is located in the Assembly Line Diagnostic Link (ALDL) connector terminal "G". The ALDL is located on bottom of Instrument Panel (I/P) hush panel, to the right of steering column.
Old Apr 26, 2006 | 11:41 PM
JBert's Avatar
Car: Looking
Cool thank you!
What was this bypass wire that I heard about within the engine bay??
Bogus info?
Old Apr 27, 2006 | 12:08 AM
slick88gta's Avatar
Car: 88 GTA
Engine: 350 L98
Axle/Gears: 3.45 9 bolt posi
maybe the computer controlled advance that you disconnect when setting initial timing?
Old Apr 27, 2006 | 01:54 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
That is correct.
Old Apr 27, 2006 | 08:19 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There is a fuel pump test connector either under the hood or at the ALDL connecter as indicated above... If there isn't a pin in the right spot at the ALDL connector, look under the hood (on a TPI it should be by the fuel pump and cooling fan relays at the drivers side) for a red wire with a black female blade connector. Apply +12VDC to that, and the pump should engage..
Old Apr 27, 2006 | 12:49 PM
Elephantismo's Avatar
Car: 91 z-28
Engine: 350 F code
Transmission: 5spd
That must be why it shows two orange power wires right before the oil presure saftey switch in the diagram... one of them runs up in the engine bay for diagnostics.
Old Apr 27, 2006 | 01:02 PM
1991L98G92's Avatar
I believe the underhood connector is green and it looks a lot like the cc carb M/C solonoid dwell connector and is probably somewhere near the battery.
Old Apr 28, 2006 | 08:14 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Thanks!
That connector is the Set timing disconnect.
1991L98G92 last post shows the Fuel Pump Bypass, just apply 12v to it with the key off. This is where my 88 has it.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
