idling problem with 87 tpi 350 iroc
Old May 4, 2006 | 03:50 PM
87iroc350conn's Avatar
i have a 87 iroc 350 tpi and it idles to low. it's got a brand new tps, iac, plugs, wires, computer, chip, maf, etc. the computer tells the car to idle at 550 so in park the car stalls, in gear it usually stays running but the idle fluctuates around 600 -650. engine was rebuilt before i got the car so it's possible the cam isn't stock. anyone have any idea what the problem could be?
Old May 6, 2006 | 09:10 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
do a search on ...setting minimal idle air...
Old May 6, 2006 | 09:30 PM
redlsed88's Avatar
Car: 1991 Z28 Convertible
did you check the idle screw or the adjustment on the tps?
Old May 8, 2006 | 10:41 AM
yep checked the tps and the iac and properly adjusted them ... did find out however that one of my injectors seems to be bad. I'm gonna get a new set of accel 24# injectors and hopefully thats where the problem is ... i guess i'll find out next week.
Old May 8, 2006 | 09:16 PM
joejoe's Avatar
Car: red one
DONT DO IT....accel injectors= JUNK.....goto; fiveOmotorsports.com, look into the 'pink' injectors
Old May 9, 2006 | 04:37 AM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
vacume leaks. especially around runners at the base. once you get it idling. spray carb cleaner at gaskets and see if idle changes. just one thing to check
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 11, 2015 03:17 PM
