Car wont start, i did a search!
Old May 8, 2006 | 10:52 AM
C6matt's Avatar
Car: 05 C6, 91 z28 Vert, 66 Mustang vert
Engine: Ls2, TPI 350, 289 4bbl
Transmission: T-56, T-5, C4
Axle/Gears: 3.42,3.08,3.73
Ok, the car was sitting for a few years, I bought it not running. It cranks over and has strong spark. unless its a super quiet fuel pump I dont hear it when I turn the key on... si I think that may be the problem, It supposedly ran great when It was put into storage ( the motor has 500 MI on it, I have all the reciepts, and the block is a very clean white, you can tell it was painted when it was all apart because the bolts arn't white...and no overspray on anything else)
So, from what i've learned using the "search" is that it could be the fuel pump relay, the oil pressure switch or the pump itself.... on post said to jumper the "ALDL" to test the pump... how do you do that? any other ideas what it could be? Its a M5 if it matters... (and its a 305 tpi unit on a 350, it has accel 30Lb injectors as well) Thanks!
Old May 9, 2006 | 05:32 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Check the fuse by the battery, this feeds the ecm and fuel pump circuit.
30# injectors won't prevent it from starting, but if your running the stock chip
it'll run pig rich. The stock chip is looking for 22# injectors
Old May 11, 2006 | 03:03 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
hook 12v to the G term. of the ALDL.
I would get rid of the accel (had no luck with them)
Ghettobird52
Jul 5, 2024 11:18 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
Wade787b
Sep 29, 2015 01:15 PM
hokis
Aug 9, 2015 03:57 PM
