need more air?!!!
Old May 9, 2006 | 06:43 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
need more air?!!!
I'm running a 350 .30 over w/400 crank-385 cu, tpi (after market intate & runners eld w/ xtra porting) 30lbs injectors twin 58mm tb dui hei w/8.8m wires shorty headers( cuz its lovered 2in all around) and afr 23deg heads. Cam is a hyd roller 612 int 621 ex. My best time at the 1/8mile w/m&h 305/40/16 slicks off nos was 7.23@98mph and on the juice (150 shot) was 6.019 @106mph. the original air intake box is still there but i have cut out the mas screens and fins also the boxes under the air cleaners. any sug. as how to get more air in this ride without turbo or super chrgr?
Old May 9, 2006 | 09:10 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
mini ram
TPiS
Old May 11, 2006 | 02:43 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Yup you have done all you can with the TPI . Go stealthram , or like said above Miniram , but I like the stealthram better
Old May 11, 2006 | 04:51 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
I'm thinking of a LT1 90degree throttle bodie snout then my maf then one of those tunner 4in pipes going down to a huge cone filter, or flipping the y shaped air box upside down and cutting 2 holes in the hood and making a real ram air! ??????
Old May 11, 2006 | 08:37 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I think you should design your own intake. A guy in Mustang Performers took two bullet shaped mufflers, make 4 runners 6'' long strait into the intake manifold and then connected the two muffers with a smooth pipe. two throttle bodies ect. all in all it was worth 64 hp and 20 lb ft tq. well worth it.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
