can somone help with a 89 formula
Old May 14, 2006 | 04:50 PM
bigdadsinn1977's Avatar
Car: 1989 formula
Engine: tpi 5.0
i have a 89 formula with a 5.0 tpi and when it start' s it's hard to keep it running .but when it starts to warm up a bit it will idle up to about 1800 rpms and sevice engine light shuts off.and then when you shut the car off it s really hard to get started again you have to push gas down to get it running again .thanks brandon
Old May 14, 2006 | 05:48 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
wow. start by checking your choke and TPS sensors other than that check for vacum leaks
good luck
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
