holley afpr install ?'s
Old May 19, 2006 | 09:50 PM
Sir Stangkilla's Avatar
i'm just got my old fpr off and was wondering if the metal ring w/ the lip needs to be tranferred over to the holley unit? i searched the forums and found one guy that asked the same question but no one answered.
Old May 20, 2006 | 02:53 AM
Vader's Avatar
Does the Holley FPR have a stamped steel spring can or a machined housing? How thick? Any instructons for the unit? (I wouldn't be surprised if there were none, being a Holley part.)
Old May 20, 2006 | 08:35 AM
oops dbl post
Old May 20, 2006 | 08:53 AM
it did have instructions. and it came w/ a housing, spring washer, new spring, and a diaphragm. the instructions say to reuse he torx screws and the base, but the old fpr had this like washer ring w/ a lip on it. Does it need to be reused looks like it does but the intrustructions say nuthing
Old May 20, 2006 | 09:55 AM
Vader's Avatar
I know the reinforcement ring, but don't know if the Holley spring can is strong enough to support itself without it or not.
If the small Torx bolts are long enough to reach through both the ring and spring can, and still provide at least 6-8 threads, I'd say use the reinforcement ring. If the screws are not long enough, the flange of the spring can is thicker, and is probably strong enough to seal the diaphragm/gasket without the reinforcement ring.
Old May 20, 2006 | 10:57 AM
it fits on there so i'm gonna try it w/ it if it leaks or some other crap happens i'll take it off
Old May 20, 2006 | 11:46 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
You won't need to use the old ring.
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 19, 2015 10:02 PM
86IROC112
Aug 17, 2015 02:00 PM
