Engine shuts off when shifting from drive to reverse
Old May 20, 2006 | 02:41 PM
knightbird123's Avatar
Old May 20, 2006 | 05:00 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Pull some codes, if the MAP is bad it should have something stored.
Where dose your motor idle in drive, if to low, that will make it die.
Old May 20, 2006 | 05:23 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Might need to replace or clean IAC motor and passageway.
camaro11j
Sep 19, 2018 08:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
Fronzizzle
Aug 9, 2015 01:15 PM
