Low oil pressure
Old May 24, 2006 | 01:50 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Low oil pressure
I swapped in a new engine and I'm having a problem. The oil pressure goes to about 10 psi on the gauge when its running. It could be a bad sender, but before I switch it I'm trying to figure out what resistance the sender should be reading at operating PSI.
Old May 25, 2006 | 12:46 AM
robert1's Avatar
Is that 10 at idle? I thought that the rule of thumb was 10 psi per 1000 RPM, so idle is ok. Does it raise up at ll when revved?
Old May 26, 2006 | 05:29 PM
Car: 86 T/A
Engine: HSR 355
It doesn't change at all when revved. And 10 PSI at idle sounds too low, my V6 and the 305 before were both atleast 30-40. I pulled the distributor but I could have sworn I reinstalled it right- is there anyway that could be the problem?
Old May 26, 2006 | 08:15 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Did you put sealant or teflon tape on the sender?
that could insulate it from ground and give you false readings.
something to check.
IIRC, a shorted sensor will read high so one that is not making good connection "may" read low.
Old May 26, 2006 | 11:32 PM
robert1's Avatar
If the distributor is seated, then it's connected to the pump. Yeah, 10 PSI while revving is too low. Is it the same sender that gave the 30-40 readings? Like JP said, if you have a good ground, and the sender wire is good, then it's the sender itself.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
