Engine Idle/Performance problem
Old May 24, 2006 | 07:38 PM
Irocz87's Avatar
Hi everyone.
I have an 87 Iroc 305 tpi. It has a cam in it and a hypertech chip. The problem is I can't get my idle down from 1500 rpms. My mechanic has been trying to fix it for days now and I figured I would post something here for additional input. The idle came down for him when he changed the timing, but when he turned the motor off then back on again, it went back up to 1500. Right now he and I are trying to troubleshoot the problem by putting the stock chip back in. Also I've added edilbrock headers and a borla exhaust. The engine is running poorly in general. It has a 4:10 rear which should be ripping up the pavement, but it's not. Thanks in advance for any advice.
Josh
Old May 24, 2006 | 08:46 PM
skid305's Avatar
Car: '89 Bastard RS
Engine: 310 TBI
Transmission: 700 R4
Axle/Gears: 3.23 Posi
Try checking the line that goes to the vapor canister, if not the clip that attaches it. Most of 'em do have a cam BTW.
Old May 25, 2006 | 02:25 PM
Irocz87's Avatar
Thanks a lot, I'll see if that helps and I'll let you know. I bought the car a few weeks ago and have been trying to get all the kinks worked out of it.
Old May 26, 2006 | 02:13 AM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Moving to TPI board.
Old May 26, 2006 | 05:13 AM
Vader's Avatar
After you check the EVAP purge line, also check the PCV valve and hose, TPS voltage, throttle stop screw, power brake booster for leakage, EGR valve for leakage, usual gasket leaks, and IAC valve for sticking.
Old Jun 12, 2006 | 10:01 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Do you get a check engine light? If you do, check the coolant temp sensor, my camaro had a very similar problem and that's what it turned out to be.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
