code 43
Old May 28, 2006 | 03:17 PM
kickasscamaro's Avatar
Car: 1985 camaro z28
Engine: 305 tpi
code 43
do any of u guys think a exhaust leak at the y pipe can set a code 43? theres a leak right where the 2 pipes off the manifold come together. the car has no power at a 1/4 pedal or more.
let me know what u think
Old May 28, 2006 | 08:45 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
knock sensor
Old May 28, 2006 | 10:56 PM
Engine: 305 tpi
when i first got this car a couple years ago, the retards that had the car before me, put washers on the bolts between where the y pipe and the cat connect to make it louder , and it had a code 43. i took out the washers and tightened everything back down and the code went away. now that i blew a hole in the y pipe the code came back. so, u dont think the knock sensor could pick that up as false knocks?
Old May 29, 2006 | 08:43 AM
Car: 1991 Z28
Engine: SBC
o yea it could...i know my y pipe isnt welded by the previous owner and rattles like crazy...and sometimes i get a check engine light flash. Wound up being code 43...now that i think about it..the thing rattles like crazy when im stopped. I think you just solved my problem too haha.
Old May 29, 2006 | 05:55 PM
Engine: 305 tpi
how does ur car run? mine runs like **** all the time, but only get a SES light once in a while.
Old May 29, 2006 | 08:53 PM
Car: 1991 Z28
Engine: SBC
runs fine...i just the ses light for like 5 secs then it goes out every now and then when i come to a stop..
sounds like you might have a problem somewhere else
Old May 30, 2006 | 02:49 PM
Engine: 305 tpi
my problem prolly is just a faulty knock sensor then
Old May 30, 2006 | 10:57 PM
Car: 1991 Z28
Engine: SBC
most likely, probably just retarding timing like crazy causing the no power and ****ty running conditions
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
