Synthetic Oils
Old May 31, 2006 | 08:44 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Synthetic Oils
what is the BEST synthetic oil to use, out of these brands?
AMSOIL....
ROYAL PURPLE....
I would like to know your thougths.
joe
Old May 31, 2006 | 09:49 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Valvoline.
Old May 31, 2006 | 09:56 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Royal Purple, I only say that because I've used it in my dads Corvette, and its worked well.
Old May 31, 2006 | 10:06 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Ive used Valvoline for over 10 years. In pretty much everything I own. I just put 20w50 full synthetic in my Trans Am. My car seems to like it alot.
Old May 31, 2006 | 10:56 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
but i use 10w30 in my car
Old May 31, 2006 | 10:58 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
I've used the Valvoline Synthetic High Mileage in my car, when I had my old TPI in it. Worked good I got better oil pressure.
Old Jun 1, 2006 | 08:03 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Theres only a handful of true "synthetic oil" out there.
Mobil 1, Amsoil, Redline, Royal Purple.
The rest are just more higly refined dino oil.
Just something to be aware of when paying for overpriced suposedly synthetic stuff.
later
Jeremy
Old Jun 1, 2006 | 10:28 AM
Vader's Avatar
Correct. Search for "Group 3 synthetic" and "group 4 synthetic" and you'll see what the differences truly are.
Just because the bottle reads "synthetic" and you think you're using, synthetic, you might not actually be using synthetic. The molecules of Group 3 OILs are not synthesized from other molecules, but merely highly refined. We USED TO call that "good oil" instead of "synthetic" lubricant. Molecules of a true synthetic are created from the polymerization of ethylene gas. The base products were never near a crude oil field. "Phony synthetic" or Group 3 is made from additional hydro-cracking of refined crude oil base stocks. That's a huge difference when the oil goes into service and starts to heat, oxidize, and break down the long molecules more readily than a true synthetic.
If it has olefin base made by Ethyl, Royal Dutch Shell, Exxon/Mobil, Conoco/Phillips, of some imports (not likely) it might be real synthetic. Otherwise, calling it "synthetic" is like calling a Hyundai a "sports" car.
Old Jun 1, 2006 | 11:00 AM
HD4mula's Avatar
I use Royal Purple on my toys and Mobil 1 on my wife's SUV. Nothing else. Lots of info out there on why doing it
Old Jun 1, 2006 | 11:30 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Any of the true synthetics should be at the top of the list. As for what's best, that depends on what you use for criteria.
Old Jun 1, 2006 | 01:55 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I use Royal Purple in my GTA for all the fluids. The reason why I use it?? Well simply because I saw it on HorsePowerTV one day, they gained 8.5rwhp in a 200? SS by simply changing all the fluids to RP. SOLD!!
Old Jun 1, 2006 | 08:13 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
I was a manager at Valvoline back in the day. We took all the classes and went to all the tech schools. When you learn about it, you learn to trust it. Nothing goes in my car but Valvoline Synthetic. 10W40 in my Jeep, 20W50 in my Trans Am. When you learn 1st hand how a company stands behind there product....Thats all I needed to hear.
Old Jun 1, 2006 | 09:03 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
Mobil 1
Old Jun 2, 2006 | 08:43 PM
joejoe's Avatar
Car: red one
Thanks to all that posted.
VADER: I will to a search on it.....
3.8TrannsAM: thats why I only asked about the AMSOIL, & ROYAL PURPLE.
I use the Royal Purple in my HARLEY DAVIDSON, it works vary good in it.
joe
Old Jun 2, 2006 | 08:55 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Someone told me that if you use synthetic oil....you can't switch back to a regular grade. Is that true?
Old Jun 2, 2006 | 09:11 PM
joejoe's Avatar
Car: red one
I was told the same thing, but the truth is ....I do not know...
Can anyone tell us if this is true or not?????
Old Jun 3, 2006 | 01:56 PM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
I like Mobil 1
Old Jun 3, 2006 | 02:04 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
If you believe everything you see on TV.....I've got a bridge out here in Calfornia I'll sell you...REEEAAALLL cheap.
I wonder how many times they had to test it to get the higher reading. And were they testing it with the hood closed?
Old Jun 3, 2006 | 03:39 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
im acutally thinking about synthetic soon for my car. But to add to the topic of synthetics, is it true that its "thinner", hence why on older motors it goes right through the seals?
I think my valve seals are kinda busted on my new 355...will switching to synthetic hurt anything or help?
(not trying to thread jack)
Old Jun 3, 2006 | 06:37 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I use nothing but Mobil One
Old Jun 4, 2006 | 02:16 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
2006 Corvette ZR-1 ships new with Mobil 1. If its good enough for that car it's good enough for my 87 TA. I have heard amsoil & royal purple are good too. If you are just driving on the street save some money & go Mobil 1.
Old Jun 5, 2006 | 05:26 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Mobil 1 Synthetic Oil
I found this link very informative:
Synthetic Oil Life Study
I used Mobil 1 in a 4 cylinder Pontiac Grand Am and the engine was still getting the same gas mileage at 212,000. To date it is still on the road at a hefty 259,000. I have also seen other testing where the Mobil 1 Synthetic outlasted all other oils. I also know that Acura, BMW, and Mercedes use Mobil 1 synthetic and only require an oil change every 10,000 miles.
Hope this helps!
Old Jun 12, 2006 | 08:59 PM
Talon's Avatar
I have been using Mobil One for over 10 years, if that tells you something.. I used it first in a chevy truck S-10 2.8,V-6 and it raised my idle speed 250 rpm's right off the bat.. I only changed my oil and filter every 15,000 miles... When I finally got rid of the service work truck it had over 280,000 miles and ran like it did when it had 40,000 miles on it, never did smoke, rattle or knock... Made a believer out of me, and I'm still using Mobil One in all of my vehicles. Also, I use mobil one's very best oil filter...
Old Jun 12, 2006 | 10:25 PM
Iroc_man's Avatar
Car: 87 Iroc
Axle/Gears: stock posi
they say amsoil is "supposidly" the "best" synthetic oil, but i use mobil 1 in my Iroc.
Old Jun 12, 2006 | 10:37 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
once you use synthetic you can switch back to regular oil without any problems. synthetic oil will not break stuff or really cause any problems.
thats for the guys above who asked. worst case thing that might happen is it might free some of the sludge already in your motor around the seals and cause it to leak alittle more to start. but generally synthetic oils are also better at swelling the seals back up to shape so give it some time and you should be leaking less oil then when you prolly first started
I use mobil 1 myself but the main reason for that is it is easy to grab. unlike amsoil or royal purple where I would have to order it I can go to just about any store and grab some mobil 1 synthetic.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
meeklay812
Oct 1, 2015 03:46 PM
