Replacement Injectors?
Old Jun 1, 2006 | 07:26 AM
LeonardS's Avatar
I removed the Multec injectors in my 92 Z28 with a 5.7 liter engine. They are stuck from sitting too long. Who makes a quality replacement injector that fits like the original? I prefer not to have yellow or pink or some other bright color. Gray or black would be great. The GM injectors are $80 each. OUCH!
By the way, it was a royal PITA to get the lower front bolt on the passenger side out of the intake runners!!!! Be prepared to take your time when you decide to replace your injectors.
Leonard
Old Jun 1, 2006 | 07:54 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Injectors?
Start to finish about 2.5 hours or so :-)
Well, for quality injectors I would suggest just getting the Ford Racing/SVO injector and calling it a day.
Best way to do it would be to change the injector constant in the chip.
Injectors will run you about 220$ or so.
Stock replacement ones are junk and you pay way too much for them.
later
Jeremy
Old Jun 1, 2006 | 08:04 AM
LeonardS's Avatar
Originally Posted by 3.8TransAM
Injectors?
later
Jeremy
Do you have a part number for these? Can I purchase them at a Ford Dealership or where? Will they fit like the stock injectors with the lock ring?
Thanks for the advice!
Leonard
Old Jun 1, 2006 | 11:43 AM
bubba353z's Avatar
Car: 07 Honda CR-V
Engine: Yes, there's one in there...
Transmission: One that shifts itself
Check the rating on the Ford injectors. I think they are rated at a lower fuel pressure than the GM injectors - i.e. they will flow more fuel than the rated value at the TPI's fuel pressure. I think they have slots for the locking clips, but can't confirm that 100%.
I think they are based on 38.5 psi, whereas the GM's are at 45psi (someone please correct me if my numbers are off).
Jeg's has them:
JEGS High Performance - Ford Racing Hi-Flo Injector Kits
Old Jun 1, 2006 | 11:48 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Get the SVO injectors, and get and adjustable fuel pressure regulator, cuase you'll need one eventually anyways.
Old Jun 1, 2006 | 11:55 AM
LeonardS's Avatar
I won't be changing the fuel press. reg. because the car only has 125 total miles on it. I just want to put a quality injector on it so I don't have to do it again.
Leonard
Jeg's has them:
What does the stock GM injector flow? 24 lbs.?
I would like to find someone who has done this swap so I make sure I am getting the correct injectors.
Old Jun 1, 2006 | 12:10 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
go to the summit racing website (summitracing.com ?) or better yet give them a call. Members here use the SVO injectors all the time.
According to the ACCEL fuel injector catalog your stock injectors were 21 lbs.
Old Jun 1, 2006 | 12:13 PM
LeonardS's Avatar
I am looking for those people that are using the SVO injectors so I can see what they used and get the correct part number.
Old Jun 1, 2006 | 12:41 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Check this thread
https://www.thirdgen.org/forums/tpi/...+SVO+injectors
Old Jun 1, 2006 | 12:47 PM
LeonardS's Avatar
Thank you for the post!!
Old Jun 1, 2006 | 02:23 PM
slowest1's Avatar
19lb inectors Bosch style GM TPI
I have a set of 8 injectors that I bought new last year from Advance Auto,only used for 8k miles. I just upgraded to 24lb injectors and I have these 19lb's sitting in a box showing absolutely no signes of use at all. I want $110 for them shipped anywhere in the US,that is 1/3 of what I paid for them new and will not accept a penny less. I have no trader feedback on here but I do on www.corral.net (zx3) www.popsracing (zx3) and Ebay (danthelister). I accept USPS money or PayPal - Welcome for payments. tabesperon@yahoo.com is my email
Old Jun 1, 2006 | 03:14 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
Leonard
That's amazing. I would see why you wouldn't want to change anything, and you shouldn't (I'm assuming that those are original miles on the car, or is it the motor?).
Old Jun 1, 2006 | 03:17 PM
LeonardS's Avatar
Thats the total on the car!!
Old Jun 1, 2006 | 05:46 PM
bubba353z's Avatar
Car: 07 Honda CR-V
I believe that 305's has 19's, and 350's had 22's. I put Accel 24's on my 350.
Old Jun 1, 2006 | 06:15 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
SHOW US PICS OF THIS CAR! IT'S GOTTA BE BEAUTIFUL!! You came across one with only 125 original miles on it?!?!? DAMN!!!
You could do what I did. Send your stock injectors off to Cruzin Performance. The owners name is Rich, and he's a REAL nice guy. He took my injectors, on my car, which sat for 6 years, and has 96k on it, and rebuilt them, with new o rings, pintle caps and screens, and sonic cleaned them. He will even send you a before and after flow chart. He got ALL of mine in equal specs. I had 2 injectors hardly flowing at all till he rebuilt them. All that for 100 dollars total, including shipping. You won't be dissapointed. Besides, I'd keep a car like that all stock. That is one of a kind and a serious collectors car.
Old Jun 1, 2006 | 10:56 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I don't think Rich does Multecs. The Ford ones won't look like the Multecs either. If you still want working replacements use the search feature and type in Ford Injectors. You should come up with a slew of threads.
Old Jun 2, 2006 | 08:08 AM
LeonardS's Avatar
I bought the car new. It was the last car built at the Van Nuys plant prior to it closing.
Old Jun 2, 2006 | 08:43 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Just a note on this.....the bosch's are louder than the multecs....just so your aware of this and don't think something is wrong when you install them.
Old Jun 2, 2006 | 11:30 AM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
125 miles !!!!!!! How could you have kept that car for 14 years and not drive it everyday. Id like to see this car.
Old Jun 2, 2006 | 11:54 AM
bubba353z's Avatar
Car: 07 Honda CR-V
Barrett-Jackson anyone? I'd imagine that car would sell for a nice $.
Old Jun 2, 2006 | 12:23 PM
LeonardS's Avatar
Give me your e-mail address and I will send you some photos.
Old Jun 2, 2006 | 12:30 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
zman_3835@msn.com
I cant wait to see what a 125 mile Z28 looks like. Usually you only see the Turbo Trans Ams or GTA's with this kinda mileage.
Old Jun 2, 2006 | 12:51 PM
LeonardS's Avatar
zman_3835@msn.com
Just sent the photos to you.
Old Jun 2, 2006 | 01:23 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
On a car like that I think that I'd just bite the bullet and buy a new stock set from GM.
If you know the part number you may be able to get them for a lower price at gmpartsdirect.com
Old Jun 2, 2006 | 02:07 PM
LeonardS's Avatar
I am going to send the original set to Rich at Cruzin Performance to have them cleaned. Then I will put them in storage. I am ordering a set for an 87 IROC 5.7 which I will leave in so the car will start and run better. Rich suggested this and I think he is right on the money.
Old Jun 2, 2006 | 04:24 PM
mnorton's Avatar
Engine: 305 LB9 TPI
What type are you going to put in the car?
The Ford 22 lb. injectors are pink ya know....
Old Jun 5, 2006 | 07:45 AM
LeonardS's Avatar
I am going to put a set of original 87 5.7L injectors in the car. They will look like the originals except the plastic on them is black instead of gray.
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
