will an 87 tpi fuel rail work on a 91 z
Old Jun 6, 2006 | 08:05 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
just like the title says will it?
if not are there any mods to make it work.
im asking cause im seling a set to a guy that needs one for his z.
Old Jun 6, 2006 | 08:41 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
yes and no
87 still had the cold start valve(AKA 9th injector). If I remember right you can just unscrew the valve feed line from the end of the rail. so he would have to seal the end of the rail where the feed line goes
Old Jun 6, 2006 | 08:44 PM
Engine: 383 HSR EBL
what if he just left the injector where it is but didnt plug it into anything whould that still suffice.
Frozer!!!
Jan 19, 2024 04:55 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
