Setting Engine Timing Using Inductive Light Question
Old Jun 9, 2006 | 04:45 PM
castro's Avatar
Hi everyone, quick question I want to adjust the timing on my z28. Engine label says 6 degrees before top dead center (BTDC). Ok so I started the car ran it a bit to get the temp right then parked the car disconnected the EDL while the car was running and then checked the timing. I am using an inductive light gun (with a dial) so I hooked it to the #1 plug and set the dial on the gun to 6 degrees. I then pointed it at the plate and it is showing up at 6 which means my timing is correct. Just wanted to make sure that is the correct way of using the timing gun.
Old Jun 9, 2006 | 05:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
According to what you've just described, you've got 12 degrees... 6 on the comb plus the 6 degrees on the gun.
When you're using a dial-back light, you set the dial on the light to the advance you want, and then line the balancer mark up to the zero mark on the comb.
Old Jun 9, 2006 | 06:12 PM
castro's Avatar
Apeiron thank you for the reply.
Wow so my timing is advanced. I have been running the car like that for a few years...thats the last time I set the timing on the car. I can't believe I haven't felt any problems till now.
So to recap I have to set the dial on the gun to 6 degrees and then shot and make sure the it zeros on the comb.
Old Jun 9, 2006 | 06:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Set the dial to 0 and turn the distributor until it's 6 on the comb, or set the dial to 6 and turn the distributor until it's 0 on the comb.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
