TBI to TPI in Firebird
Old Jun 14, 2006 | 07:15 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
I have an '89 TBI Firebird. In my car, the battery is on the right-hand (passenger) side. All of the TPI Firebirds I've seen have the battery on the left-hand (driver's) side of the car. is this correct and, if so, what is involved in swapping to TPI?
Old Jun 14, 2006 | 07:36 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'm in the process of rounding up parts for my own swap. Pretty much to do it right you'll need a complete TPI, wiring harness from a Firebird (the Camaro is different for the battery and canister wiring),ecm, fuel pump,high pressure fuel inlet hose (your TBI one won't cut it),TPI prom chip,throttle,detent and cruise control cables,knock and TPS sensors,dual fan setup (if you wish but it's not necessary) and some form of air intake. Not to mention the needed gaskets,hoses and such.
BRoss99
Aug 10, 2025 05:08 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Randomtask2
Aug 13, 2015 01:57 AM
Sanjay
Aug 12, 2015 03:41 PM
