Corvette Heads
Old Jun 15, 2006 | 10:45 AM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Corvette Heads
I'm planning on swapping the stock heads on my L98 for a pair of ported aluminum L98 heads. For those of you who have done this, what should I expect? What are some of the things to look out for?
Old Jun 16, 2006 | 01:05 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
The don't have the cross over so you need to have an external EGR put in ....like the vette
Old Jun 16, 2006 | 01:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The center 4 intake manifold bolts are at the old style angle.
RBob.
Old Jun 16, 2006 | 03:39 PM
TPeye's Avatar
Engine: 350ci
thanks for the info guys.
For the EGR, do you think I would be able to hook up with the cast iron exhaust manifolds? I'll have a machine shop take care of the angle of the bolt holes for the intake.
Old Jun 17, 2006 | 07:33 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Your compression will go through the roof as well. your heads have a 64cc chamber and the Al L98 heads have a 58cc chamber. Thats why they work so well on 305s.
Frozer!!!
Jan 19, 2024 04:55 PM
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
TreDeClaw
Aug 14, 2015 06:58 PM
