Power in Start pos.,but nothing happends
Old Jun 20, 2006 | 03:37 PM
RiceKiller87's Avatar
Car: '87 IROC
Transmission: 700-R4
Car is an 89 IROC with an L98/auto. The computer was tuned and the VATS were tuned out.
I have a wiring diagram in a Hanyes manual and I have found that I DO have power at the yellow wire in the START position. The diagram shows the yellow wire going from the ignition switch on top of the column to the Starter Enable Relay and then to the neutral safety switch...we arent getting power at the neutral safety switch when we try and start the car.
So my question is where is this starter enable relay located?
If the VATS are tuned out of the computer like my dad said they are,you dont still have to do the resistor bypass correct?
When I turn the key on,the radio has power,fuel pump primes,get the buzzer...yadda yadda yadda but whe you try to start it NOTHING happends,not even a click or attempt. The headlights come on as well and the battery is pretty new.
Any help is greatly appreciated.
Old Jun 21, 2006 | 09:14 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
probably a dead spot in the starter . Get some one to tapp the houseing while the key is turned ahead .
Old Jun 21, 2006 | 11:25 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
dead spot or a bad safety switch.
You said that the switch is not seeing the power, you may have a broken wire going to it as well.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
