Cubic inches and TPI
Car: 71 NOVA, 2003 HEMI RAM
Engine: 502 AFR heads, huge solid roller
Transmission: 400TH
Axle/Gears: 9" 31 spline 3:70 gears
Hey guys,
With motors between 400 and 450 cubic inches (small block)
Which aftermarket fuel injection would be best suited? I have never seen any numbers on max displacement for any given vender.
Looking for power, drivability, and emissions legal (if that’s possible)
Would a carb be a better choice?
I want a large displacement small block for street cruzing.
Car: 86 Z28 Project
Engine: Currently 305 TPI soon 355 tpi/vort
Transmission: Bah 700R4
Dont know bout a max displacement for a after market fuel system, bigger injectors and an ecm tune? personaly i like havin a nice fuel hoggin 4 barrel sittin on top but then again thats my opinion
The SuperRam is finicky to install but is good for up to 1000 CFM. I belive the Mini Ram is close to the same. Any of the Non standard TPI systems are designed to run larger CID. Factory stuff or Even factory stuff replaced with bigger stuff eg. ASM Runners arent going to do the trick. The biggest bottle neck in TPI isnt the runners as everyone likes to point to but the factory Base intake plate. I have seen numbers for flow to prove this. I will try to look them up to back my statements.
If you just want somthing "large" to kick butt on the street, a S/R, would be a good choice if emissions are a must. When you decide to get every ounce of power at the track, pick a manifold that is better suited for the additional airflow.
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
so, Mr. Dewynter:
does using the Edelbrock TPI base help out? if so, by how much? just wondering, since I have a couple of 400 blocks laying around and contemplating a TPI 406 (since I've invested so much effort & acquired knowledge in TPI), but concerned about exactly these type of bottlenecks.
Transmission: 400TH
I guess I'm looking to hear from people that have dynoed their 383+ cubic inch motors. I have a feeling that the TPI type intakes physically can't flow enough air to support large cubic inches.
Does anyone have a supercharged 383+ cubic inch motors? with some typ of TPI?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by super_nova_71
Which aftermarket fuel injection would be best suited? I have never seen any numbers on max displacement for any given vender. I want a large displacement small block for street cruzing.
Bigger injectors, along with the right tune to optimize performance, and you'll be absolutely fine. Again though, the stock TPI unit is only temporary, just until you have all of the accompanying bugs, that always seem to come about when swapping to bigger cubed engines, worked out.
Originally Posted by RPOL98
so, Mr. Dewynter:
Car: 90 IROC
Engine: 5.7L TPI
Dewynter:
thanks for the answer. I ported the Edelbrock base somewhat just to clean up the machining transition to the as-cast surfaces. am using SLP runners, 52mm TB, and ported plenum. I'm still tuning the fuel curve though.
Sanjay
Aug 12, 2015 03:41 PM
