IAC Adjustment
Old Jun 22, 2006 | 10:16 AM
dynomaximal's Avatar
Car: 1981 Z-28
Transmission: Muncie M-20
Axle/Gears: 3:42
IAC Adjustment
I was reading "IAC and TPS Adjustment" at
https://www.thirdgen.org/tpimod2,
when do I remove the clip from the ADAL pins?
Old Jun 22, 2006 | 09:56 PM
78camaroz28's Avatar
Car: 2001 Trans Am WS6
Check out this thread...I've read it about 4 times today...
https://www.thirdgen.org/forums/tech...nimum+air+idle
Specifically Fast355's post...
Originally Posted by Fast355
Wrong procedure! Jumper the ALDL connection, turn on the key, disconnect the IAC, remove the paper clip, start the engine, adjust the minimum air, now plug back in the IAC, kill the engine, disconnect the - battery cable to clear the codes.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
thejimsterz28
Sep 30, 2015 08:52 PM
