Spark .. and control module
Old Jun 23, 2006 | 08:31 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
can you still get a spark out of a bad module.....as in if you pull a plug and ground it spin the motor and get a desent spark... can the module still be bad...causing a no fire or start, even with starting fluid
Old Jun 23, 2006 | 12:20 PM
Vader's Avatar
An HEI amplifier/switching module which operates when cold or at low RPM/load can fail to operate when warm or under heavier load. It's best to test the module by switching exercises under a coil load for a period of time, to allow the hardware to warm up and reveal any thermal flaws. You can take it to many chain/franchise parts stores and have it tested at no cost. Ask them to test it four times in succession to thoroughly heat it under load.
Old Jun 23, 2006 | 02:46 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
They are under 20 dollars. Buy that and a rotor and keep a extra on hand. The test may show they work when they do not as well.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 03:05 PM
