DO TPI engines use the plastic toothed timing chain gears??
Old Jun 22, 2006 | 09:19 PM
Sleeper_Z's Avatar
Car: Golden yellow 1987 IROC-Z
I was wondering if the plastic toothed timing chain gears were used in the TPI engines? I know my 83 and 84 Z28s had them, but I dont know if the TPI engines used them. My 83 was an LG4 and my 84 was an L69. Thanks for the help.
Jeremy
Old Jun 22, 2006 | 11:22 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
It's possible. The '89 L98 I rebuilt had pieces of nylon in the oil pan, presumably from when the OEM cam gear shredded. I also found a fairly new GM steel timing set when we pulled the front cover off.
Old Jun 22, 2006 | 11:31 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
my 88 iroc has steel timing gears and steel chain, stock
Old Jun 23, 2006 | 10:54 AM
Guest
Guest
Posts: n/a
My 85 and 86 both had the nylon gear.
Old Jun 23, 2006 | 11:28 AM
HOZZ4's Avatar
Car: 1988 CHEVROLET IROC-Z
Engine: 5.7 TUNED PORT INJECTION
Transmission: 700R4 AUTOMATIC
MY '86 HAD A NYLON COVERED GEAR. IT BIT IT AROUND 160,000 MILES. IT WAS A 5.0 TPI MOTOR. I JUST REPLACED IT WITH A DOUBLE ROLLER TIMING SET AND THE MOTOR IS STILL RUNNING GREAT.
Old Jun 23, 2006 | 11:35 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
My 87 had steel gears. Looks like this might be the cutoff year for factory steel.
Old Jun 23, 2006 | 02:26 PM
Damon's Avatar
I have worked on a bunch of 87s and I don't recall any of them having the nylon top timing gear. I'm sure that would have caught my attention if it had one.
88-up I'm almost certain they were all steel gears.
Old Jun 23, 2006 | 02:59 PM
Sleeper_Z's Avatar
Hmm 87 might be the cut-off year. Thanks guys for all the info. We will see if this 88 Im getting ready to work on had nylon or not. Thanks again.
Jeremy
Old Jun 23, 2006 | 03:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
87 would make sense, since that's when the timing set changed for the factory roller cam.
Old Jun 23, 2006 | 04:07 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
That makes sense Aperion.
My TTA had a nylon coated gear, but they were flat tappet cammed as well.
My 91 Formula also had steel gears
later
Jeremy
Old Jun 23, 2006 | 05:22 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
At about 183,000 miles my 83 Z28 "died" on the way to work one morning. No gas, no spark, no oil pressure when cranking. When we tore the front down we found the chain had slipped off a very worn steel timing gear. It's an HO car/motor. I'm not saying it's the original gear, but it was pretty well worn down to nubs and it looked like a lot of wear for a replacement timing gear.
The_Phoenix
Sep 3, 2015 10:56 PM
jharrison5
Aug 19, 2015 05:53 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
